Komp zamula, wolno działające programy, zwiechy systemu
Postprzez Gazownick » 03 Wrz 2010, 03:10
PostUA: Mozilla/5.0 (Windows; U; Windows NT 6.0; pl; rv:1.9.2.8) Gecko/20100722 Firefox/3.6.8 (.NET CLR 3.5.30729)
Gazownick
Dołączenie: 03 Wrz 2010, 01:42
Re: Komp zamula
Postprzez mateo8898 » 03 Wrz 2010, 15:21
PostUA: Mozilla/5.0 (Windows; U; Windows NT 5.1; pl; rv:1.9.2.8) Gecko/20100722 Firefox/3.6.8
Files to delete:
C:\Windows\System32\drivers\pyymtcya.sys
C:\Users\jude\AppData\Roaming\fvgqad.dat
C:\Windows\system32\drivers\autwapxq.sys
Drivers to delete
pyymtcya
autwapxq
Odinstaluj zbędne toolbary: Windows Live Toolbar oraz Google Toolbar
DRV - File not found [Kernel | On_Demand | Stopped] -- C:\Windows\System32\Drivers\vaxscsi.sys -- (vaxscsi)
DRV - File not found [Kernel | On_Demand | Stopped] -- D:\NTGLM7X.sys -- (SetupNTGLM7X)
DRV - File not found [Kernel | On_Demand | Stopped] -- C:\Windows\System32\DRIVERS\nwlnkfwd.sys -- (NwlnkFwd)
DRV - File not found [Kernel | On_Demand | Stopped] -- C:\Windows\System32\DRIVERS\nwlnkflt.sys -- (NwlnkFlt)
DRV - File not found [Kernel | On_Demand | Stopped] -- D:\NTACCESS.sys -- (NTACCESS)
DRV - File not found [Kernel | On_Demand | Stopped] -- C:\Windows\System32\DRIVERS\ipinip.sys -- (IpInIp)
DRV - File not found [Kernel | On_Demand | Stopped] -- D:\INSTALL\GMSIPCI.SYS -- (GMSIPCI)
DRV - File not found [Kernel | On_Demand | Stopped] -- C:\Users\jude\AppData\Local\Temp\RVI3230.tmp -- (GarenaPEngine)
DRV - File not found [Kernel | On_Demand | Stopped] -- D:\FXDrv32.sys -- (FXDrv32)
DRV - File not found [Kernel | Auto | Stopped] -- C:\Windows\System32\DRIVERS\EagleNTy.sys -- (EagleNTy)
DRV - File not found [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\EagleNT.sys -- (EagleNT)
DRV - File not found [Kernel | On_Demand | Stopped] -- C:\Users\jude\AppData\Local\Temp\catchme.sys -- (catchme)
DRV - File not found [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\agp440.sys -- (agp440)
O28 - HKLM ShellExecuteHooks: {AEB6717E-7E19-11d0-97EE-00C04FD91972} - Reg Error: Key error. File not found
C:\Users\jude\AppData\Local\Temp*.html
C:\Windows\tasks\GoogleUpdateTaskMachineCore.job
C:\Windows\tasks\GoogleUpdateTaskMachineUA.job
"RtHDVCpl"=-
"HP Software Update"=-
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run]
"ISUSPM"=-
[clearallrestorepoints]
Klikasz Wykonaj skrypt. Dajesz log z usuwania + nowe logi z OTL + log z GMER
Kolejność jak podałem.
Re: Komp zamula, wolno działające programy, zwiechy systemu
Postprzez Gazownick » 04 Wrz 2010, 00:53
Gazownick
Postprzez mateo8898 » 04 Wrz 2010, 09:03
PostUA: Mozilla/5.0 (Windows; U; Windows NT 6.1; pl; rv:1.9.2.8) Gecko/20100722 Firefox/3.6.8
Mało co się usunęło, bo wygląda na to, że źle skopiowałeś skrypt. Rób to uważnie, aby niczego nie zgubić. Windows Live Toolbar nadal nie odinstalowany.
Do Avengera wklej:
Files to delete:
Drivers to delete
pyymtcya
nfsoyxe
autwapxq
W OTL wklej:
@Alternate Data Stream - 64 bytes -> C:\Users\jude\Documents\Wideo004.avi:TOC.WMV
"RtHDVCpl"=-
"ISUSPM"=-
Postprzez Gazownick » 04 Wrz 2010, 23:07
Gazownick
Postprzez mateo8898 » 05 Wrz 2010, 09:22
Teraz się usuwanie OTL udało, więc spróbujmy nim ruszyć to, z czym ma problem Avenger.
W OTL wklej:
DRV - File not found [Kernel | Boot | Stopped] -- C:\Windows\System32\drivers\hpfd.sys -- (nfsoyxe)
:Services
pyymtcya
autwapxq
[reboot]
Postprzez Gazownick » 05 Wrz 2010, 20:52
Gazownick
Postprzez mateo8898 » 06 Wrz 2010, 00:19
Jednak OTL nie dał rady wszystkiemu. W takim razie zastosuj ComboFix i daj log z niego.
Postprzez Gazownick » 06 Wrz 2010, 01:00
Gazownick
Postprzez mateo8898 » 06 Wrz 2010, 01:05
Wklej do notatnika:
Folder::
c:\program files\DAEMON Tools Toolbar
File::
Driver::
pyymtcya
gupdate1ca14cd72130fe
Registry::
[-HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\pyymtcya]
Plik -> zapisz jako -> CFScript.txt
Przeciągnij i upuść ikonkę CFScript.txt na ikonkę ComboFix.exe
Rozpocznie się usuwanie i powstanie log, który dajesz na forum.
Postprzez Gazownick » 06 Wrz 2010, 01:48
Gazownick
Postprzez mateo8898 » 06 Wrz 2010, 10:50
Ok, usunięte.
W OTL kliknij Sprzątanie
Zainstaluj SP2 -> http://www.instalki.pl/programy/downloa ... ack_2.html
Zainstaluj jakiegoś antywira.
Postprzez Gazownick » 08 Wrz 2010, 01:01
Log z Malware - http://wklej.eu/index.php?id=501b9b37de
Po instalacji SP2 miałem problemy z brakiem dźwięku, odinstalowałem sprzęt by został ponownie wykryty przez system. Teraz co prawda dźwięk jest, ale często wyskakują mi komunikaty typu "Gniazdo zostało podłączone", "Gniazdo zostało odłączone" w Menadżerze Realtek HD Audio.
Gazownick
Postprzez mateo8898 » 08 Wrz 2010, 13:43
Chyba nie użyłeś opcji Sprzątanie w OTL, bo w logu z Malwarebytes jest wykryty obiekt w kwarantannie ComboFixa, której już być nie powinno. W takim razie Pobierz OTC uruchom i kliknij CleanUp (Vista: Prawoklik -> Uruchom jako administrator)
Możesz jeszcze opróżnić kwarantannę Malwarebytes.
Odinstaluj sterowniki od dźwięku (nie sprzęt, ale całe oprogramowanie sterownika), pobierz najnowszą wersję ze strony producenta i zainstaluj ponownie.
Postprzez Gazownick » 09 Wrz 2010, 00:17
PostUA: Mozilla/5.0 (Windows; U; Windows NT 6.0; pl; rv:1.9.2.9) Gecko/20100824 Firefox/3.6.9 (.NET CLR 3.5.30729)
Odinstalowałem stare sterowniki, zainstalowałem nowe. Teraz nastąpił problem w postaci mikrofonu, mianowicie mnie nie słychać (jest bardzo cicho, na tyle że nikt mnie nie zrozumie nawet jak dam suwaki na maxa) :| Same problemy mam z tym Realtekiem i z tego co widziałem szukając w google nie tylko ja.
EDIT. OK chyba już działa
Gazownick
