Odinstaluj
Spybot - Search & Destroy (stare próchno), Conduit Engine, Norton Security Scan (zbędny), Vuze Remote Toolbar, Akamai NetSession Interface i Unity Web Player .
Następnie pobierz i uruchom Autoruns
http://www.instalki.pl/programy/downloa ... oruns.html i odznacz, a następnie usuń w Nim wpisy
RtHDVCpl, IAStorIcon, ISBMgr.exe, NortonOnlineBackupReminder, StartCCC i ALLUpdate.
Następnie uruchom OTL
w oknie Własne opcje skanowania/skrypt wklej:
- Kod: Zaznacz wszystko
IE - HKLM\..\URLSearchHook: {ba14329e-9550-4989-b3f2-9732e92d17cc} - C:\Program Files (x86)\Vuze_Remote\prxtbVuz0.dll (Conduit Ltd.)
IE - HKU\S-1-5-21-414799013-1703767741-1511448005-1000\SOFTWARE\Microsoft\Internet Explorer\Main,SearchDefaultBranded = 1
IE - HKU\S-1-5-21-414799013-1703767741-1511448005-1000\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://search.babylon.com/?AF=100482&babsrc=HP_ss&mntrId=dcec01e00000000000007edd08dd6ebc
IE - HKU\S-1-5-21-414799013-1703767741-1511448005-1000\..\URLSearchHook: {ba14329e-9550-4989-b3f2-9732e92d17cc} - C:\Program Files (x86)\Vuze_Remote\prxtbVuz0.dll (Conduit Ltd.)
IE - HKU\S-1-5-21-414799013-1703767741-1511448005-1000\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyOverride" = 127.0.0.1:9421
FF - prefs.js..browser.search.defaultenginename: "Search the web (Babylon)"
FF - prefs.js..browser.search.order.1: "Search the web (Babylon)"
FF - prefs.js..browser.search.suggest.enabled: false
FF - prefs.js..extensions.enabledItems: [email protected]:1.0.53.2
FF - prefs.js..keyword.URL: "http://search.babylon.com/?AF=100482&babsrc=adbartrp&mntrId=dcec01e00000000000007edd08dd6ebc&q="
FF:[b]64bit:[/b] - HKLM\Software\MozillaPlugins\@microsoft.com/GENUINE: disabled File not found
FF - HKLM\Software\MozillaPlugins\@microsoft.com/GENUINE: disabled File not found
FF - HKLM\Software\MozillaPlugins\@real.com/nsJSRealPlayerPlugin;version=: File not found
FF - HKCU\Software\MozillaPlugins\@unity3d.com/UnityPlayer,version=1.0: C:\Users\Sebastian\AppData\LocalLow\Unity\WebPlayer\loader\npUnity3D32.dll (Unity Technologies ApS)
[2010/12/13 23:08:52 | 000,000,000 | ---D | M] (Vuze Remote Toolbar) -- C:\Users\Sebastian\AppData\Roaming\mozilla\Firefox\Profiles\qxf5d9a9.default\extensions\{ba14329e-9550-4989-b3f2-9732e92d17cc}
[2011/03/23 14:54:06 | 000,000,000 | ---D | M] (Battlefield Play4Free) -- C:\Users\Sebastian\AppData\Roaming\mozilla\Firefox\Profiles\qxf5d9a9.default\extensions\[email protected]
[2012/02/01 02:28:47 | 000,002,310 | ---- | M] () -- C:\Program Files (x86)\mozilla firefox\searchplugins\babylon.xml
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoActiveDesktop = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoActiveDesktopChanges = 1
O8:[b]64bit:[/b] - Extra context menu item: E&ksportuj do programu Microsoft Excel - res://C:\PROGRA~2\MICROS~1\Office12\EXCEL.EXE/3000 File not found
O8:[b]64bit:[/b] - Extra context menu item: Funkcja Google Sidewiki - res://C:\Program Files (x86)\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_E11712C84EA7E12B.dll/cmsidewiki.html File not found
O8 - Extra context menu item: E&ksportuj do programu Microsoft Excel - res://C:\PROGRA~2\MICROS~1\Office12\EXCEL.EXE/3000 File not found
O8 - Extra context menu item: Funkcja Google Sidewiki - res://C:\Program Files (x86)\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_E11712C84EA7E12B.dll/cmsidewiki.html File not found
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} http://java.sun.com/update/1.6.0/jinstall-1_6_0_16-windows-i586.cab (Java Plug-in 1.6.0_16)
O16 - DPF: {CAFEEFAC-0016-0000-0016-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_16-windows-i586.cab (Java Plug-in 1.6.0_16)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_16-windows-i586.cab (Reg Error: Key error.)
C:\Users\Sebastian\AppData\Local\Temp*.html
C:\Windows\tasks\*.job
C:\Users\Sebastian\AppData\Roaming\.#
C:\Users\Sebastian\AppData\Roaming\Unity
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{70991E0A-1108-437E-BA7D-085702C670C0}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{96D0B6C6-5A72-4B47-8583-A87E55F5FE81}]
[resethosts]
[clearallrestorepoints]
